Your Transmission
This is a place for members to vote
Which type of transmission?
Automatic
55
70%
Automatic with overdrive
19
24%
Manual
1
1%
Manual with overdrive
4
5%
Total votes: 79
Bob Lemke
Handle: deckofficer
Re: Your Transmission
Post by Bob Lemke »
I did the same Bill, played with the numbers for all the gears, not just the top gear. I haven't checked the site's calculator, does it lay it out for the the gears? I know when I played with the numbers I thought I sure didn't need the lower 1st gear that comes with OD trans, but I just short shift the first two gears anyway.
Handle: frank
Post by frank_a »
I don't need a calculator, I know I need a 700R4, but how long are those babies? I have less than an 18" driveshaft with a short tailpiece TH350.
I have a 3.74 rear end, running 31" tall tires and seems to me I'm doing 3500 rpm at 65 or so. It's been a couple years, so I don't remember eggsackly.
What would I have to do welding-wise or bolt-on bracket-wise to swap my TH350 out for a 700R4. Wouldn't need to worry much about balance on that driveshaft...
Frank
Big Bill
Handle: Big Bill
Post by Big Bill »
700 is 2 inches longer than a standard 350 turbo
Handle: frank
Post by frank_a »
Thanks bill, that helps.
I see there is a long and short version: long ones 2wd, and short ones 4wd. Which are you runnin? This is where I got that info: http://www.gmtruckhq.com/?q=700r4-4l60_ ... story.html
Is there electronic/computer stuff I'd need to do, seeing there is no computer in the hot rod? What sort of stall rpm for the torque converter?
Thanks!
Frank
Zandoz
Handle: Zan
Post by Zandoz »
700R4 connected to a lightly modified GM 60V6 on one end, and a 3.73 Ford 8.8 locker on the other...in a light weight, short wheelbase T modified. Wellllll....at least that is what it will be when it's done.
Return to “Members Polls”
