Jarrett's 27 roadster
Re: Jarrett's 27 roadster
Cooter posts on fb: "We thinking. Gotta make some mounts for radiator. Looks high to me? Jarrett Don't know if he even likes it or not. So here it is
— with Jarrett Cothern."
Jarrett 24.jpg (143.75 KiB) Viewed 1063 times
Jarrett 25.jpg (149.91 KiB) Viewed 1063 times
Jarrett 26.jpg (149.5 KiB) Viewed 1063 times
cooter
Handle: Cooter
Post by cooter »
Cooter
Bruce Pickett
Handle: T-Test
As long as the shroud isn't lower than the oil pan, you should be good,
If later you want to install a hood, put it level with the cowl and add a metal band under the radiator shroud to match the hood depth. :)! 8-) :?:
Cory posts on fb: Got the radiator done!
cooter
Handle: Cooter
Post by cooter »
Cooter
cooter
Handle: Cooter
Post by cooter »
Cooter
Cooter posts on fb: "Jarrett with his new steering column. Thanks to Clate D. Reed.
You're the the bomb, Clate."
A tight squeeze?
Steering box bracket. Welding 101!
Progress continues . . .
Ackerman??? . . .Close enough!
