LayzNC
Handle: Martin
Post by LayzNC »
This week my alternator came in. Because the ford radiator outlet is on the drivers side I mounted the inline electric water pump on the drivers side.
So I needed to mount the alternator on the passenger side. There was not alot of room to mount it in the correct position because of the front engine plate. So I checked with my local alternator shop to see if I could run the alternator backwards. He said yes it will still charge. But he said the fan running backward might not cool the alternator as well. With the limited amount of driving that I will be doing I dont think this will be a problem.
So I ended up making my own mounts. I wanted a threaded tensioner so it couldn't work it self loose. I had that problem on my old engine using a
sloted bracket. Hope everyone's winter projects are going well.
Good job on the alternator. That's what hot rodding is all about - creative solutions to problems. :)!
fwestrup
Handle: Hot Rod Fred
Post by fwestrup »
Martin, its looking good, I take it we will not be see you at Run to the Sun next month. Great job.
Looking good Martin!!!
LayzNC
Handle: Martin
Post by LayzNC »
fwestrup wrote: ↑Wed Feb 16, 2022 2:01 pm Martin, its looking good, I take it we will not be see you at Run to the Sun next month. Great job.
Fred, I was trying but the car won't be ready. I will try to go on Saturday depending on the weather.
LayzNC
Handle: Martin
Post by LayzNC »
Test fitted the torque converter for the second time. The first time the pilot bushing was to small. Ultimate converters used a BBC pilot buehing.
So I had to send it back to be cut off and changed to a BBF. I used a billet TCI Ford flex plate with a Chevy bolt pattern. A chevy converter with a
Ford pilot bushing. And a Chevy power glide trans with a Reid bell housing to bolt to a Ford engine. Nothing about this build went easy.
Also fabricated two lugs to weld on the frame for rear shock mounts.
Good work, Martin. Getting closer . . . !
Making good progress Martin! Where did you get those Mickey Thompson rear tires? I need to replace mine and I cannot find them (29x18.00 R15LT) anywhere.
LayzNC
Handle: Martin
Post by LayzNC »
Finally finished the pre assembley. After spending a few days welding and sanding the frame, I decided it would be easier to fill the small
imperfections with a little bondo and epoxy paint the frame instead of powder coating it. Because the powder coating is baked on at 550
degrees you need to use a metal filler for any imperfections. Hopefully the final assemebly will go quick.
GH010683_Moment (2).jpg (263.13 KiB) Viewed 901 times
That paint should suffice for the frame. It's also easier to remove if welding is necessary in the future. Good work! I'm even getting excited, and you must be over the moon!!!
