Removable dash?
Handle: frank
Re: Removable dash?
Post by frank_a »
Okay, I get it now. I needed to look at the 1st pic posted not the 2nd!
So Bob, what does the screw fasten too? Just threads made in glass. or is that a metal body? I'm gonna need something behind mine to attach it to so it's easy to come out. My wiring needs to get cleaned up too, and it would be relatively easy to do with a removable dash.
Thanks!
Frank
Bob Lemke
Handle: deckofficer
Re: Removable dash?
Post by Bob Lemke »
It is old hand laid up thick fiberglass. A metal nut was glassed in place to receive the two machine screws.
Krovette
Handle: 23 Iowa Bucket
Re: Removable dash?
Post by Krovette »
I did much the same as Bob but used 1/8" aluminum diamond plate and fastened it to the cutout fiberglass dash with stainless socket head bolts and locknuts.
Keep your head in the clouds and the rubber on the road.
Handle: frank
Re: Removable dash?
Post by frank_a »
I gotta tell ya, I like Bob's idea of embedding a nut in glass and then just using machine screws! I get a ways to go to get there, but she's coming right along. Me and the puppy are going down to work on stuff right now!
Frank
Re: Removable dash?
There is a product called a nutsert, which you install like a pop rivit and can be used with wood, fiberglass, metal, etc. depending on the thickness of your material. When installed, they provide a machine thread and come in amll to large thread diameters.. They are easy to install and work extremely well! IF using them with fiberglass I would use a washer to spread the clamped load over a larger surface, but that is just my opinion :)..
Handle: frank
Re: Removable dash?
Post by frank_a »
I've used those in woodworking projects Rolla, and was thinking that would work well. Thanks!
Frank
Re: Removable dash?
Rolla I suppose you know someone that would sell a fellow some of them? How small an order can that person handle?..............
Handle: frank
Re: Removable dash?
Post by frank_a »
Seems to me I got mine individually in a hardware store...
Frank
Big Bill
Handle: Big Bill
Re: Removable dash?
Post by Big Bill »
Harbor Freight sell the whole kit cheap including the installation tool and an assortment of sizes.
Re: Removable dash?
Actually Mike, Big Bill is right, there is a very inexpensive assortment through Harbor Freight and many local harware stores carry them. You don't actually have to sue the tool to cripm them. You can insert the correct size screw in them and crimp them in place. On the larger diameters it is actually easier to use an impact or something of that type to crimp them :)..
