Brake drag
Re: Brake drag
Bill Cleveland wrote:No RPVs in my system. Don't need 'em. :roll:
PS - Thinking more about possible causes, I have had to adjust the rod that goes from the base of the pedal into the M/C piston to get the pedal to firm up before it hits the firewall; if I adjusted it too far in, maybe I am covering up a 'vent port' or something? I don't know much about brake M/C's :? :?:
Yeah I don't use a RPV either, but I have drum on all four wheels.
Yes there is a port to refill the lines, like when you bleed the brakes. You have to fill
the brake line again somehow.
I think you would want some free play in the linkage. That could be your problem, it's
worth a try. Should be simple enough and quick to do.
Bob Brunell
Handle: TINMAN
Re: Brake drag
Post by Bob Brunell »
Spanky. make sure the brake pedal is returning all the way. If you have a pedal return stop, make sure it's not adjusted as to keep pressure on the M/C push rod /piston...Bob
