Canton has a good reputation in the racing community. You should be OK with their pan.
That will do the job I bet................. :)! :)! :)! :)! :)!
LayzNC
Handle: Martin
Post by LayzNC »
This week the timing cover and fuel pump came in. I decided to run the fuel pump off a cam drive setup. The pump is a Enderle 600 mechanical
punp @ 9.2 GPM. Keith Fulp motorsports in Atlanta GA. custom machined a stock timing cover to mount the fuel pump. He also machined a front engine mounting plate. I will be using the front engine mounting plate as a timing cover. So I don't need to use the small cover that came with it.
The mounting plate is notched to sit on my frame rails. I will need to weld mounts on the frame to bolt it in.
There will also be a mid plate between the engine and bell housing to mount the rear of the engine.
Nice Work........... :)! :)! :)! :)! :)! :)!
Looking good, Martin. With the torque that monster is likely to produce, strong engine mounts are a must! :)!
Martin - Given this project and all that is involved, I think that you will need a different nickname! :lol: :lol: :lol:
LayzNC
Handle: Martin
Post by LayzNC »
I had to take it easy on the spending the last two week and let my wife calm down. LOL. Took her out to buy a new pocketbook and were good to go.
This week my Comp roller rockers and new fuel fill cap came in. I am having to make a new fuel tank. My old tanks fill cap and sending unit will not work with methanol. Also the outlet on the old tank is 1/4" and no return lines. The new fuel pump will need a 3/4" supply line and a 1/2" return line.
20210206_130131 (1)a.jpg (194.74 KiB) Viewed 800 times
Way to go, Martin. You're getting there! I think most of us can sympathize with the spending thing . . . it seems to add up before you know it. :?
The wife can add up cost better that anyone,,,,,Trust me I know that......... :)! :)! :)! :)! :roll: :roll: :roll:
Martin - I applaud your progress! If you need any help, please hollar!
