Stopped by the machine shop today and was told they will start on my motor Monday. I am hoping to take some pictures of the assembly
process to post in the next few weeks. This week the valve covers came in. They needed to be at least 4" tall to clear the stud gridle.
And because I am running a soild roller setup the valve covers will need to be removed often to adjust the valves.
I decided to go with fabricated aluminum covers made by Williams Perfomance in Lake Elsinore CA. The quality of his work is excellent.
Also this week I ordered the blower and fuel injection hat. If I don't post next week I might be living in the garage and don't have internet.
Hopefully my wife will calm down by then. LOL.
- LayzNC
- Senior BucketHead
- Handle: Martin
- 20210212_135327a.jpg (32.92 KiB) Viewed 1012 times
- 20210212_135417a.jpg (38.18 KiB) Viewed 1012 times
- 20210212_135533a.jpg (33.32 KiB) Viewed 1012 times
Looks awesome, Martin. Be sure and tell the wife how pretty she looks (and . . . Sunday is Valentine's Day!)
- rbsWELDER
- Handle: rbswelder
Martin,
Those welds sure look purty!
- LayzNC
- Senior BucketHead
- Handle: Martin
Thanks for the reminder Bill. Looks like I will be spending Valentine's Day at the mall.Bill Cleveland wrote: ↑Fri Feb 12, 2021 11:05 pm Looks awesome, Martin. Be sure and tell the wife how pretty she looks (and . . . Sunday is Valentine's Day!)
- LayzNC
- Senior BucketHead
- Handle: Martin
Good news this week, They started working on my engine. Thing should go fairly quick now. I went by there yesterday and they just finished line honing the crank. This week they also finished honing the cylinder bores and cutting the second keyway in the crank and balancer. Monday they will per Assemble the bottom end to measure the deck height. Then zero cut the block. Hopefully the final assembly will start this week.
- 20210219_161411a.jpg (166.19 KiB) Viewed 980 times
- 20210219_161304a.jpg (146.54 KiB) Viewed 980 times
- 20210219_161707a.jpg (88.92 KiB) Viewed 980 times
Looks great, Martin. Will you dyno the motor before installation?
- rbsWELDER
- Handle: rbswelder
Progress!
- LayzNC
- Senior BucketHead
- Handle: Martin
Yes, I am planning to. Also planning to video the startup, break in and dyno pulls. I will post a link to the video.Bill Cleveland wrote: ↑Sat Feb 20, 2021 11:10 am Looks great, Martin. Will you dyno the motor before installation?
The week before i will post the engines specs, boost and fuel setup.
If anyone wants to take a guest what it will make.
- LayzNC
- Senior BucketHead
- Handle: Martin
This week they pre assembled the bottom end and measured the piston to deck hight, The tallest one was .018" below and the deepest was .024
The block was a little out of square. But there is plenty of room to fix it. I was a little worried that the used block could have been cut down once before and with the stroker crank and rods the pistons would be sticking out of the block. I also starting polishing the engine mounting plate.
Not as easy as it looks on Youtube.
The 8-71 blower and intake from the Blower shop came in this week. I will try to get it assembled this week.
- 20210226_160953a.jpg (55.07 KiB) Viewed 956 times
- 20210226_160934a.jpg (34.82 KiB) Viewed 956 times
- 20210224_170524a.jpg (58.16 KiB) Viewed 956 times
- 20210225_175854a.jpg (134 KiB) Viewed 956 times
