Bill Cleveland wrote: ↑Sat Feb 27, 2021 3:31 pm Lotsa bling on this motor, Martin. Gonna be a show winner! :)!
Absolutely!
LayzNC
Handle: Martin
Post by LayzNC »
Stop by the shop this week and Tom was honing the wrist pin bushings. When they blueprint an engine they keep a log book with all
the tolerances and specifications for the entire build. You can bring the engine back three years from now to get checked out and they
can tell you if its within specs or not.
This week I also finished polishing the front engine plate and started polishing the valve covers.
Nice work! Gonna turn some heads . . . :D :)!
LayzNC
Handle: Martin
Post by LayzNC »
Been busy this week getting my T bucket ready for the "Run To The Sun" car show in Myrtle beach SC. March 18,19 and 20th.
If anyone is planning on going stop by and say hello, Always nice to meet new friends. I will be parked along the east side of the show with
the Queens City Hot Rods club.
I also wanted to explain why this engine build is taken long than normal. Tom the man building my engine retired from Heintz brothers
a year and a half ago after building engines for the past 50 years. He came back this year to help the shop get caught up. lucky for me he
specializes in building Ford engines. The bad thing is he only workes two days a week. But thats OK.
This week I finished polishing the valve covers and installing the blower drive. The Enderle injector hat came in. But the pump saver
Alkydigger sent was wrong. You can see in the picture below. Tom said Tusday he will start assembling the bottom end Tusday.
fwestrup
Handle: Hot Rod Fred
Post by fwestrup »
Martin, Cheryl and I will be there however we will not be bringing the T Bucket . Plans right now is to bring the 442 if I can get the fuel problems worked out. If that doesn't happen it will be the Falcon they are talking rain on Thursday and Friday. We always park in the inside in the sand not sure why, I 'll make sure to stop by and see you.
I like roller coasters !!! ..... Can I get a ride in this T ???
TN nationals maybe ?
Looking Real Good Martin!!!
LayzNC
Handle: Martin
Post by LayzNC »
We made it back from the" Run To The Sun show". Cold and very windy. Nice meeting with you Fred, looking foward to talking again in TN.
Last week they were supposed to start assembling the bottom end but apparently they had alot of toruble balancing the Eagle crank.
The crank came unbalanced. Tom said he spent most of the day working on it. Alot of drilling and a little welding to get it right.
Hopefully next Tusday they will start assembling it. Also this week the intake came back from the polisher.
LayzNC
Handle: Martin
Post by LayzNC »
last week we had a few issues, The fuel pump adapter that bolts to the cam shaft uses a small set screw to help stop it from spinning.
Tom was afraid it could work loose and spin. So we decided to drill out the set screw hole and extend the cam sprocket dowl pin.
Now the cam, cam sprocket and the adapter are all pined together Tom also installed the crank, rods, pistons and degreed the cam.
We had another issue with the main gridle. It needed to be ground for more clearance
for the counter weights. I was told by Canton that it would clear a 4.5" stroke. Mine did'nt.
LayzNC
Handle: Martin
Post by LayzNC »
Despite a few more set back, We made good progress this week. The Canton oil pan and pickup tube both had to be modified to fit.
The second 3/16" keyway in the balancer was cut to small and also had to be modified.
This week Tom finished the bottom end, front timing cover, engine plate and installed the heads. Today he measured and ordered the push rods.
I am hoping things will go together a little quicker now.
