- LayzNC
- Senior BucketHead
- Handle: Martin
We had a good week, The push rods came in and the valve train is completed. Hand cranked the oil pump to check oil flow to all the rockers.
had 85 psi cold. Tom also installed the intake manifold, pop off valve and mounted the blower. Had a small problem, The blower pulleys didn't line up.
I needed to order a 1/4" shim for the crank pulley. I also needed to order a fuel pump spacer so the fuel line will clear the blower belt.
I was hoping to run the fuel lines behind the belt but there was not enough room.
- 20210419_143059a.jpg (47.58 KiB) Viewed 941 times
- 20210419_143051a.jpg (60.94 KiB) Viewed 941 times
- 20210421_161626a.jpg (46.92 KiB) Viewed 941 times
- 20210421_161639a.jpg (66.26 KiB) Viewed 941 times
- rbsWELDER
- Handle: rbswelder
Martin - Some minor annoyances, but the big things are getting done! Progress!!!
- LayzNC
- Senior BucketHead
- Handle: Martin
Last week the 1/4" shim problem turned in to a bigger problem. The Blower shop said they don't sell shims for the crank pulley.
And they don't recommend using the smaller diameter top pulley shim on the crank pulley. So I bought a two groove accessory
pulley and had it machined down to 1" thick. Now the pulleys line up with no shims.
The fuel pump extension moved the pump out past the blower belt and we were still able to run the fuel lines and returns
behind the belt. Had another prolbem with the distributor. MSD makes a short crab top distributor for a blower set up.
But because I am using Kaase SR71 heads with a 3/4" raised intake the distributor it hit the intake manifold.
Luckily because of the extra 3/4" a standard height distributor with a small diameter cap just fit.
A few more little thing and we will be ready for the dyno.
- 20210507_110621a.jpg (67.5 KiB) Viewed 908 times
- 20210507_110840a.jpg (98.78 KiB) Viewed 908 times
- fwestrup
- Senior BucketHead
- Handle: Hot Rod Fred
Martin, looking good, I cant wait to hear it fire up.
- Handle: Hitec
Awesome and anxious to hear a dyno run as well. Keep on keeping on.
Hitec
Hitec
- rbsWELDER
- Handle: rbswelder
Can't wait to hear this running!
- LayzNC
- Senior BucketHead
- Handle: Martin
Been very busy with work the past two weeks, But I did manage to bring the engine home, As you can see from the pictuers I will need to do alot of work to fit this engine in my car so I decided to wait until the fall, winter to swap out engines. I still need to build a trans, shorten the rear end, change gears and switch the rear to disc brakes. This week I ordered the throttle cable mount, fuel shuttoff cable mount, AN16 thermostat housing.
I made the engine stand to the same dimensions as my frame.The only problem is my car frame is not long enough.
- 20210514_171936a.jpg (100.98 KiB) Viewed 881 times
- 20210514_171920a.jpg (105.23 KiB) Viewed 881 times
- 20210514_172202a.jpg (71.18 KiB) Viewed 881 times
That's an awesome mill for any vehicle, let alone a T-bucket. Talk about a ground pounder . . .
