So, Martin, will you push the drivetrain back or extend the frame? If so,how?
- LayzNC
- Senior BucketHead
- Handle: Martin
Bill, Right now the car has a 96" wheel base, so I don't have room to move back. I am planning to extend the front of the frame 12"
This way I will only need to move the front hairpin mounts 12" and extend the steering rod, plus brake lines and wires.
I am also planing to switch transmissions from my turbo 350 to a power glide. should be an easy swap with the body off.
The hard part is explaining to my wife why I need a new trans.
- fwestrup
- Senior BucketHead
- Handle: Hot Rod Fred
Martin, do you have a power glide to put in it, I think I have a build one with a stall torq out in the shop.
Fred
Fred
- LayzNC
- Senior BucketHead
- Handle: Martin
Fred, I don't have one at this time, I am a little nervous about getting the trans and stall set up right. I don't want to be standing on the brake pedal
with two feet trying to stop the car from moving with the blower surge. On the other hand I don't want to have to crack the throttle to get the car to move. This is my first time building a blown Alcohol engine. And I have had to do alot of reseaching.
I am planning to run a mid-plate between the trans and block. I have been told I might need to have the torque converter made to allow for the plate.
Has your bellhousing been changed ? Or is it still stock chevy bolt pattern. Do you know what other modifications were made ?
Thanks, Fred
- fwestrup
- Senior BucketHead
Its a stock Chevy Bellhousing, Torque converters is 2000 or 2500 stall, I need to put my hands on it. Just don't ask why a Ford man has a Chevy transmission.
PowerGlides are big with the race crowd, regardless of engine brand. Cheap, lightweight, and can be built to be bullet proof. Makes sense in a torque-whomping T-bucket, too, with a high-stall convertor.
- LayzNC
- Senior BucketHead
- Handle: Martin
Been waiting for a date to dyno the engine. I was told last month it would be around the third week in July and they had nine engines ahead
of me. In the mean time I finished installing the throttle cable mount and the fuel shut off cable mounts. So the engine is ready to go.
Also been working on the transmission. I am using a custom built two speed powerglide with a Reid bellhousing to bolt up to a BBF. Haven't decided were to have the torque converter made. If anyone know of a good shop please let me know. The few people I already talked with all wanted to Know if I had a Dyno sheet. So I will probably wait until it's tested.
- 20210514_171841a.jpg (97.59 KiB) Viewed 765 times
- 20210704_133509a.jpg (71.97 KiB) Viewed 765 times
- 20210704_133453 (1).jpg (87.14 KiB) Viewed 765 times
- 20210704_133429a.jpg (63.2 KiB) Viewed 765 times
- LayzNC
- Senior BucketHead
- Handle: Martin
Update, still waiting on a date to dyno the engine. I been talking to Ted fischer at Engine Systems in Tucker GA. He specializes in BBF racing engines.
But he said his shop is very busy now and he dont have the time. It would take two people a hole day to break it in and test it.
if anyone knows some one near NC. with an engine dyno thats set up to test BBF on alcohol please let me know.
I found a shop in Mooresville NC but he not set up to do BBF. I would have the buy a set of dyno headers and fly wheel for just for testing.
- LayzNC
- Senior BucketHead
- Handle: Martin
I knew when I started there were going to be some problems. But it seems everything about this swap is turning into a problem.
When I bought the car the owner told me it had a 9" ford rear. And it looked like a ford 9".
Well a few weeks ago when I was unloading the car off the trailer i noticed the rear axle seal was leaking.
I was already planning to upgrade the rear end so I decided to go ahead and do it now before the swap.
It turns out it's not a 9" ford. Its a 1963 GMC rear with a 3.50 gear and a posi. And that won't work.
So I found a complete 9" ford truck rear with 3"-1/4 axle tubes on Market place. I had it narrowed 7" with large axle bearings,
411 gear with a detroit locker, Moser axles, and converted it to Willwood disc brakes.
- 20210822_085903 (2)a.jpg (23.22 KiB) Viewed 738 times
- 20210728_170926a.jpg (62.38 KiB) Viewed 738 times
- 20210731_112636a.jpg (65.85 KiB) Viewed 738 times
- 20210731_115629a.jpg (50.47 KiB) Viewed 738 times
I guess no build is without problems, but you've had an extra share! Glad you're on top of it, and I know when it finally rests between your frame rails, there will be miles of smiles!
