So glad that you decided to build a new frame for that monster.
I tried googling that number and "steering box" and it returned a lot of pictures of various steering boxes, but I di not see one like your.
fwestrup
Handle: Hot Rod Fred
Post by fwestrup »
Martin, it looks like a mopar steering box. I'm glad that you built a new frame and it looks great.
Fred
LayzNC
Handle: Martin
Post by LayzNC »
Kevin Seward wrote: ↑Thu Nov 18, 2021 9:33 pm Hey Martin, as you already must know. THAT is one heck of a power plant extraordinaire !!!! I only hope I'm lucky enough to hear it run some time some where in person. I look forward to your progress and I'm anxious for your updates.
KEEP up the excellent work and wishing you a very happy Thanksgiving.
Hi Kevin, I don't think that will be a problem. I am planing to make as many shows, cruise-ins as I can next year.
A while back, Rick "Indycars" said he would like to go for a ride. Hoping to make to the Nationals in 2022.
Had a great time in Townsend TN. I appreciate all the comments .Hope everyone had a safe and happy Thanksgiving,
Hitec
Handle: Hitec
Wellllll Martin, if you would, you can also add my name to the list who would like a ride !! :D
I'm planning to be at the Nationals as well.
Catch you later.
Hitec
LayzNC
Handle: Martin
Post by LayzNC »
Made good progress this weekend. I am still waiting on the rear engine plate to come in. So I made spacers to go between the engine and trans so I could set the engine and trans in and fit the body. After four tries and a little cutting I finally got the body on. The problem was the scatter shield for the trans was hitting the floor. Thought about lowering the engine and trans a little but I only have 6" of clearance between the ground and the deep trans pan. So I cut an 8"X8" section of the floor out and will re-fiber glass over it later. Now that exerything fits I can tack weld all the body mounts to the frame.
Hope everyone had a nice Thanksgiving.
GOPR0313a (2).JPG (185.75 KiB) Viewed 1157 times
GOPR0321a (2).JPG (165.13 KiB) Viewed 1157 times
Nice work. Getting close to reality, and I know the excitement is building. You gotta get a video of your first drive in it! :D :)!
Lugnut
Handle: Charles
Post by Lugnut »
Bill Cleveland wrote: ↑Thu Dec 24, 2020 10:15 pm WOW! That's going to be one raucous T-bucket. And . . . for all you blue oval fans, a Ford in a Ford!!!
WHO EVER HEARD OF SUCH A THING???????????????????????????????
LayzNC
Handle: Martin
Post by LayzNC »
This week the reverse mounted universal t bucket brake pedal from Speedway came in. I guess they call it universal because after you cut and reweld it to fit it becomes universal. :lol: The master cylinder kit form Wilwood also came in. I went with a remote mount so I can mount the reservoirs under the seat which will be above the calipers and I won't need to use residual valves. Also didn't want to access the reservoir thru the floor.
GOPR0332 (2)a.JPG (137.57 KiB) Viewed 1112 times
LayzNC
Handle: Martin
Post by LayzNC »
Here are some photos of the master cylinder mounted. I wanted to mount the proportioning valve to the inside but you can see
in the pictures there wasn't enough room between the frame and the trans. With the remote reservoirs mounted under the seat
I was able to closed the access hole in the floor to the old master cylinder.
GOPR0563 (2)a.JPG (104.64 KiB) Viewed 1088 times
Looking good Martin!!!
