LayzNC
Handle: Martin
Post by LayzNC »
Hope everyone had a safe and happy New Year. This past week has been very busy, The mid engine plate from Keith Fulp
Motorsports came in so I was able to weld the engine mounts in. My new radiator also came in this week. Now with the engine,
radiator and body mounted I can measure for the drive shaft, fuel shut off cable , throttle cable and start rewiring the car. Still waiting
on the electric in line water pump to finish the cooling system. This week I also ordered a fuel cell from Rock Solid Motorsports.
The old tank held 15 gallons and had a 3/8" fuel line, new one will hold 24 gallons with a 1" fuel line.
GH010600_Moment (2)a.jpg (131.89 KiB) Viewed 1363 times
GOPR0575 (2)a.JPG (169.81 KiB) Viewed 1363 times
GOPR0574 (2)a.JPG (186.89 KiB) Viewed 1363 times
Can't wait to hear this one run!!!
LayzNC
Handle: Martin
Post by LayzNC »
This past week the water pump came in and I was able to start working on the cooling system.
I also had the water inlet and outlet fittings cut off the new radiator and replaced them with AN16 fittings.
I haven't been feeling well this past week. I tested positive for strep throat. And the antibiotics also
make me feel sick. Hopefully a few days rest will help.
Sorry to hear of your illness, Martin. Get well soon!!! :|
Martin - Sorry to hear that you are not feeling well! Make sure that you rest enough to get rid of the streph.
Overall the progress looks great!
fwestrup
Handle: Hot Rod Fred
Post by fwestrup »
Martin it's looking great, hope you start feeling better.
LayzNC
Handle: Martin
Post by LayzNC »
Feeling alot better this week, But the weather turned cold this past week so I havent been doing much. The shop in heated but when the
temperature out side is 17 degrees it still feels cold. I did manage to finish making up the water lines. And the fuel cell from
Rock Solid Motorsports came in this past week. Starting to feel like this project is never ending.
Lookin' Great Martin!
LayzNC
Handle: Martin
Post by LayzNC »
This week I installed the new fuel cell from Rock Solid Motorsports in Statesville NC. It holds 24 gallons and was a tight fit.
The problem is the back of the front seat is tapered back. So the opening for the tank is smaller on the top than the bottom.
So I had the front of the tank angled to match the seat back. Now the tank is 3" wider on the bottom and you need to twist
the tank slightly to get it in.
Great progress! Great components!
I can't wait to hear it!
