Hello All, I purchased this T bucket with little or no info It is a kit car but from the drive-train I believe it was built in the 60's as most of the donor parts are late 50's chevy, the transmission and rear end are both 57 chevy.
My questions are related to the front end, I am hoping someone here can identify the front end so I can replace the king pins which need to be replaced. I am also hoping someone can tell me what the alignment specs are. Last question, an old time hot rod guy has told me that the front axle should lay back 3 to five degrees (which creates a problem because there is no way to make this adjustment) yet the guy at the alignment shop says that if the axle has king pins the axle stays straight. Thanks in advance for the info.
Thanks,
Jay
Help me identify
jayhall1962
- Baby BucketHead
- Handle: Jay
Help me identify
- BUCKET1.jpeg (562.07 KiB) Viewed 472 times
- BCKT4.jpeg (411.36 KiB) Viewed 472 times
- BCKT3.jpeg (624.69 KiB) Viewed 472 times
- BCKT2.jpeg (589.95 KiB) Viewed 472 times
Re: Help me identify
Jay, Welcome to the site, and I could very well be wrong but I will disagree with you alignment fellow......
I have a straight axle as do many many T Buckets that are in this family and most if not all will have the axle laid back about 6 degrees. I know mine is and it drives very good........
Now that axle looks like an early Ford to me and could very well be a truck axle that has been drilled. So I think you are looking at Kingpins for a Ford truck App. maybe in the late 50's or early 60's. In Speedway Catalog you will find a post about the shape of the axle ends to help determine the type axle you have.......I found this in the Speedway Catalog.........
One thing I would try to do if that was mine, I would mount the tie rod on top of the steering arms, or if at all possible I would put it behind the axle.... That rod being that low to the ground is just asking for it to hit something and it may very well be below the scrub line on that car.....
jayhall1962
- Baby BucketHead
- Handle: Jay
Hi Mike,
Thanks for the welcome and the info! I agree with you about the axle lay back but this creates another problem, their is no way to make that adjustment, any ideas? Once in a while the front wheels go into a death wobble and I have been told it is because of the axle is not laid back.
I am a hot rod novice so any advice is appreciated.
Jay
Jay
- Dewey Burton
- Handle: SparkPlug
You can check the lay back with an angle finder, or the front end man can do it...the front perch should have been welded with the correct angle in it...if not you may be able to machine a wedge to fit between the mount and the spring . If you move the struts down in the back to achieve the angle , you will put a bind in the spring connection ... Welcome to the group , there is always something to fuss with on these little a cars , but you will love the enjoyment and the attention you will get , once you get everything sorted out.....
SparkPlug..Sun-Ts...Prez
Jay with the famous death wobble you need to also check for ANY Looseness in the whole front end....You need to not have any slack in the tie rod ends, the steering box and make sure the wheel bearings are tighter than a regular car. Because these cars are much lighter and they will not cook bearings like heaver cars do so make them good and snug.....As Spark Plug said there are several ways to change the angle of the axle just don't make the problem worse.....You might also try to make the "toe" out instead of toe in cause some straight axles like out not in....Lots of trial and error sometimes..........Ask questions and we will try to help.....
Once you get the bugs worked out you will have a fine ride.......
jayhall1962
- Baby BucketHead
- Handle: Jay
Sparkplug, Thanks for the info. Lowering the struts in the rear was a thought, the problem is that the Zbar for the clutch lever rides on a threaded nub, the bolt on the other side of the nub is one of the 3 bolts that hold the strut flange to the frame so if I lower the struts I am not sure how that will affect the clutch. I am confused but hope you understand what I am describing. I was thinking of replacing the struts with radius rods fitted with a ball joint style adjuster at the axle top n bottom,
Thanks,
Jay
Thanks,
Jay
- T Bucket2.png (233.8 KiB) Viewed 437 times
- T Bucket1.png (204.19 KiB) Viewed 437 times
