So with tires 10 and 1/2 inches wide, that will add about 1 and 1/4 inch to each side, or 2 and 1/2 altogether.
The little woman said I could go ahead and order wheels and tires today.
Hmm.
How to figure back space?
- Handle: frank
- Handle: frank
My old hot rod
This was my old hot rod with 15 X 15 wheels. I'm almost sure they were 5.5 inch back space, but I sold them a long time ago, so no clue.
- t1 (2).JPG (134.82 KiB) Viewed 501 times
- Handle: frank
- dezolde
- Senior BucketHead
- Handle: dezolde
Re: How to figure back space?
Yes, when you add tire cross section. You could also consider using 5.0" BS which provides a little more rim/tire clearance at the bottom plus allows a bit more for the wheels to swing inward at the top as the suspension compresses.
Jerry
- Bruce Pickett
- Handle: T-Test
One inch of clearance would be enough, but more would be better.
Other than special made wheels, back spacing is almost a set in stone choice in wheel selection.
- Bruce Pickett
- Handle: T-Test
